reset cmos? When does that messagebox show up?
https://linustechtips.com/topic/735801-help/#findComment-9341077
56 minutes ago, 8BitBuilder said:
What do I do I already turned off my computer and I can't click anything
This message usually indicates a hardware driver incompatibility, or a corrupt installation. Did you just install a fresh copy of Windows? If so, where did you get the installer from?
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/735801-help/#findComment-9341290
Yes it I fresh and I got it from the Microsoft store
https://linustechtips.com/topic/735801-help/#findComment-9342127
That looks like loading screen for laptop or prebuild. Are you trying to install Win10 over some previous version of Windows? Did anything odd happen during install process? You migght need to wipe HDD or go through OEM reset process (if partition is still there).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/735801-help/#findComment-9342252
Its a new build
https://linustechtips.com/topic/735801-help/#findComment-9343008
17 minutes ago, 8BitBuilder said:
Its a new build
Ok, well, time to run installer again. Something has clearly went wrong during install. Did it ask for drivers?
https://linustechtips.com/topic/735801-help/#findComment-9343064
2 minutes ago, 8BitBuilder said:
How do I run the installer again because I can't click anything
Clear CMOS, boot into BIOS, set USB as first device, disable fast boot. That should give you screen where it asks about booting for USB. If you can't get to BIOS, remove OS drive and connect it later back, maybe to another connector if possible.
https://linustechtips.com/topic/735801-help/#findComment-9343131
As an FYI:
if you install windows 10 under EUFI and leave your BIOS's "smart start" or "quick start" or "logo start" depending on the board enabled, it will replace the windows logo with the motherboard logo and boot like that. it's normal behaviour and actually makes boot times incredibly fast (as it doesn't load through the whole bios).
Currently got my windows 10 boot time (from power switch to desktop) to 4 seconds using only EUFI this way
But that would explain the way the display is here.
as for OP:
you're likely going to need to reinstall windows. you'll likely have to press the key to get boot menu (f12 on some boards)
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/735801-help/#findComment-9344235
Shows about my knowledge on Win10. I only have it on laptop.
https://linustechtips.com/topic/735801-help/#findComment-9344464
