Free Audio Spectrum Maker?
Go to solution Solved by Ahoy Hoy,
11 hours ago, Implosivetech said:
Does anybody know a free program that allows me to create an audio spectrum video?
If you mean like how all those youtube music video channels where they have a shape/line/circle which changes in size depending on frequncy. Its a simple effect done in after effects
Use a program like bandicam to record windows media player (spectrum visualizer) playing the audio, then use windows movie maker (also free) to mute the video and overlay the source audio file so that the spectrum is synced with the audio.
That doesn't seem high quality to me but I guess it could work
wait, it does that?
let me test
i like trains 🙂
1 minute ago, Implosivetech said:
how do u use the visualizer in windows media player. and yes, i have the original one installed from windows 7
Open a music file with WMP, right click on it and Visualizer something, I used Win7 way long ago so don't remember
2 minutes ago, Implosivetech said:
wait, it does that?
let me test
You right click when in full screen mode and there's a bunch of visualizations, the one I like best is the regular "scope".
I even put a screenshot of it as my desktop background :P
-snip-
Why not get a rainmeter skin with visualizer on it, that'd be cool
That's what that row of small bars on the bottom is ;)
  • 1 year later...
YES!.......YOUTUBE MOVIE MAKER...it's a great media SOFT ...you can create whatever you want not only spects ....effects ....shapes..masks....and much stuff trust me...Personally i use it....and it's easy to use ;). (english man :p)
That's not exactly "free" is it?
I know that Blender can do it with some scripting (there's even a little addon I found somewhere that does it automagically) but you have to render it as a movie... unless maybe you get the Alpha build and use Eevee in real time and just record it.
#Muricaparrotgang
