Will m.2 eat up my pci-e slot
TrYeX
If i put a m.2 ssd in my msi z270i will it eat up my pci-e slot ,so my graphic card will collaps due to being bullied by me for being slow.
m.2 is a different connector, it uses electronical pci-e lanes not the actual connector.
2 minutes ago, M.Yurizaki said:
No. For one NVME uses the chipset's PCIe lanes, not the CPU's where the graphics cards go to. For another, using NVMe may instead disable two SATA ports.
NVMe usually disables a PCIe slot, either an x1, x2, or x4, or eSATA ports.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Ahaa i get it m.2s only eat satas, thanks!
No they don't. they disable U.2 usually. SATA doesn't use PCI-e
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
I think it's different on every board model.
And SATA does use PCI-e.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
SATA Express does, but not SATA III (normal SATA)
if it did, then why would it be capped at 6Gbps
Desktop:
Laptop:
Both SATA and SATA Express use PCIe Lanes, just like USB, just like thunderbolt, just like HDAudio... Just like every single I/O on the MB.
It's a matter of HOW MANY.
Not sure if i should really dig into why some I/O is capped at certain speeds and why others aren't...
System specs:
The 100 series PCH contains 20 PCIe 3.0 lanes to use for connecting peripherals. How these lanes are used are up to the motherboard manufacturer. In this case, there are three NVMe capable drives, and using them would disable all of the SATA ports and three of the GbE ports, because it has to use one or the other.
whats funny most professional reviews dont mention what ports are shared or disabled.  This is important part of the buying processes now since we have limited sata and PCIE lanes
Bottom line it depends on your motherboard.  Different motherboards treat m.2s differently.  I've seen some say you can only use an m.2 or U.2, not both. Others will take the lanes from a Sata or Sata-express ports and other still will actually disable a Pci-e slot, all depending of course if you use the actual m.2 slot or a PCI-e slot.
I suggest you check your manual.
Phanteks Enthoo Elite | Intel I9 - 7900X | Asus x299 Rampage VI Extreme | MSI 1080 TI
32Gb Dominator Platinum Special Edition Blackout 3200MHz  | Samsung 960 Pro | 2x Samsung 961 Pro (Raid 0) 256Gb M.2 SSD
Samsung 850 Pro 512Gb | WD Black 4TB | Corsair AX1200i
