7 minutes ago, Dang3r D3bbi3 said:
OK great glad I could help man LMK how it goes!
Hey thanks for looking for me but I, can't install it for some reason it says "No internet connection found". I tried installing and reinstalling it but every time it says that. Thanks for the help tho
-Thanks
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330139
6 minutes ago, Droidbot said:
Learn to actually root instead of using a tool. Because if anything fucks up, it's not their fault. It's yours.
That is true but I feel like I would be more likely to fuck up instead of a tool built to root. But I will look into rooting manually
-Thanks
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330146
Sry about that man
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330152
25 minutes ago, Jackestrel said:
Is there a one-click way to root Galaxy core prime that runs Lolipop 5.1.1?
I tried Kingoroot and kingroot and both just gave the outcome: Root Failed
-Thanks
Everything you need to know about custom ROMs and rooting your phone can be found at the link below.
https://forum.xda-developers.com/galaxy-core-prime
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330180
1 minute ago, Dang3r D3bbi3 said:
Have you tried connecting to a PC and using KingoRoot that way?
Yeah I have tried solely using my phone and using my desktop.
My model is sm-g360V
LMY48B.G360VVRS3cpl1 is the build number and im running 5.1.1
in case anyone is curious
-Thanks
-Thanks
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330187
I'm using Chrome on a PC
Thats really strange since im using chrome on a PC to, ok do you have a anti-virus software or something that would cause it to stop you from going to that site. Cause when i go on it its fine.
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330237
Hmm , I go to the site scroll down to the "download iRoot app" and get the Pc version and then I cant go further
-Thanks
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330246
How to Root Verizon Galaxy Core Prime SM-G360V
February 2, 2017 by Ankur
Verizon Galaxy Core Prime SM-G360V can be rooted easily without any complicated procedure. So, if a are one of the user of Verizon Galaxy Core Prime SM-G360V phone you can root your device from here by following the below mentioned steps.Samsung Galaxy Core Prime VE Specs
After rooting you will get SuperSU app which is a superuser manager app developed by Chainfire, it give root permissions on your device once it’s rooted. In this guide we are going to use iRoot V 1.7.9.2 for rooting the device. After root you can have the root features available like flashing cutom ROMs, install custom Recovery and many other features also.
Preparing your phone:
  • Device should be fully charged up to 100%.
  • Backup all the important data to some external storage.
  • USB drivers  for Samsung Galaxy Core Prime should be installed on the PC.
  • Make a Nandroid backup of the current ROM in case you wish to restore it later.
  • Custom recovery like TWRP must be installed on the device.
  • USB debugging mode should be enabled on the device. Go to Settings > Developer options > USB debugging mode.USB Debugging
Procedure to Root Verizon Galaxy Core Prime
Follow the process mentioned below to Root Verizon Samsung Galaxy Core Prime phone easily –
Advertisements
Advertisements
  1. Download the iRoot application from here.
  2. Open the application once it is installed.
  3. Click on ROOT to start with rooting process.
  4. Allow the process to complete.
  5. Device will reboot automatically after rooting process is completed.
  6. Success message will be displayed on the screen after reboot.
Rooting the device is now completed, you can check the status by downloading Root Checker app from the Google play store.
Try this, :)
https://linustechtips.com/topic/734876-one-click-way-to-root/#findComment-9330247
