AMD 8350 HELP
Solved by SpaceGhostC2C,
I can't find information about the motherboard model in your link. However, if it doesn't support more than 16GB of RAM, it must be a very specific model, since most AM3+ boards would go to 32GB. Hence, I suggest double checking that, because his main concern is not going to be the PSU, but the power delivery on the motherboard. A weak VRM or a poorly cooled one could have trouble running an FX-8350.
In other words: the 8350 will fit, but it may or may not be a good idea depending on the motherboard. Hence, make sure you get the exact motherboard model before deciding.
