First pc build
Go to solution Solved by iRileyx,
You need an X99 motherboard to go with that cpu.
a 1060 paired with a 6800k seems a little silly.
Also for future reference, use pcpartpicker.com to make your build, it'll tell you if theres any incompatibilities so you can solve them yourself.
Hello i have now got the funds to build a new pc and i was wondering if my parts were compatible, thanks for all who help.
Here are the parts:
Intel BX80671I76800K Core i7-6800K 3.4GHz 6 Core 15MB LGA-2011-v3 Broadwell-E CPU (No Heatsink)
Asus Z170-AR Intel Z170 S1151/4xDDR4/3xPCIEx16/HDMI/DP/USB3.1/ATX Motherboard
Corsair Vengeance LPX CMK16GX4M2A2133C13 (Black) 16GB Kit (8Gx2) DDR4 2133 Desktop RAM
MSI (GTX 1060 GAMING X 6G) 6G GTX 1060 Gaming X PCI-E VGA Card
Aerocool LS5200 AIR/VR Black USB3.0 Mid Tower Case w/RAVE80+ 800watt PSU
and also attached is the links to everything
pc rig 32017.txt
https://linustechtips.com/topic/734492-first-pc-build/
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325872
For the love of Gaben, please use PCPartPicker next time. Anyways, everything is compatible.
EDIT: Derp, you need an X99 board for a 6800K.
Edited by kelvinhall05
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325875
You should try the Z270 platform since it has better OC support and works great paired with that I7 6800k which has GREAT OC capabilities.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325877
What? You're wrong at everything here :P
Z270 works with LGA 1151 while the 6800K is LGA 2011 v3, it also doesn't have GREAT OC capabilities. It's a 6-core CPU and those 6-cores don't overclock as high as 4-cored i7s
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325883
6800K needs X99...
SPECS:
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325884
PLS dont spread misinformation
i7 6800k is socket 2011-v3
z270 uses socket 1151
these are different sockets and DONT work together
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325890
It was my mistake! I misread 6800k and thought about a 6700k instead.
I am sorry for that.
TO BE UPGRADED:
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325893
What about this build instead @OP?
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  ($309.33 @ OutletPC)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($29.99 @ NCIX US)
Motherboard: ASRock B150 Gaming K4 ATX LGA1151 Motherboard  ($92.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($89.99 @ Amazon)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($73.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($379.99 @ Newegg)
Case: Phanteks ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($56.30 @ Newegg)
Total: $1161.79
Generated by PCPartPicker 2017-02-07 06:34 EST-0500
https://linustechtips.com/topic/734492-first-pc-build/#findComment-9325904
