Putting this in general, dunno if it belongs here, I thought about new builds but its not a build... anyway mods can move if wrong section.
Hey pc bros. I wanted your opinion on something. So right now I have an i5 6500, 8GB of DDR4 @ 2133 and a 480, got a small boot ssd, 1TB hdd not important, the important part is the main specs.
Well its getting to the point where my PC isn't enough for my streams, I need a quad core or better with hyper threading for the best quality so I thought about something and I wanna know what you guys think... I found fingerhut, that website where you lease monthly, better for people like me with low income, and they have some decent PCs on there. One in particular that grabbed my eye was a 6800k, 16GB, and a 1080, comes with a 240 boot drive and a 2TB HDD, link here https://www.fingerhut.com/product/NMVIN.uts and wanted your thoughts on if its worth it? For someone like me who just can't afford to dump 350 on a processor down or a 1070, would it be worth selling my PC and leasing instead? Sure its a pre built, but its in a normal case so I can still customize it later. Let me know, be honest.
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/733898-need-advice/
28 minutes ago, OnionRings said:
Don't lease your hardware man
Just wait to see what Ryzen offers should be 6c/12t chips for less than what the intel chips/X99 motherboards run
Also try using ReLive or GPU accelerated streaming in OBS in the meantime
They're listing
Item Number: NMVIN
$3,099.99
$155.00 per month*
Color/Pattern: Blue
Vs a real build for literally $1000 less for the same CPU/GPU with a bit more RAM
but ya wait to see Ryzen
PCPartPicker part list: https://pcpartpicker.com/list/fNRq7h
Price breakdown by merchant: https://pcpartpicker.com/list/fNRq7h/by_merchant/
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($409.78 @ OutletPC)
CPU Cooler: Cooler Master MasterLiquid Pro 240 66.7 CFM Liquid CPU Cooler  ($109.99 @ SuperBiiz)
Motherboard: ASRock X99 Taichi ATX LGA2011-3 Motherboard  ($209.99 @ Newegg)
Memory: G.Skill Ripjaws 4 series 32GB (4 x 8GB) DDR4-2800 Memory  ($189.99 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($69.99 @ NCIX US)
Storage: Western Digital Red 2TB 3.5" 5400RPM Internal Hard Drive  ($85.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($589.99 @ SuperBiiz)
Case: Cooler Master MasterBox 5 (Black) ATX Mid Tower Case  ($62.98 @ Newegg)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.33 @ OutletPC)
Total: $1808.03
Generated by PCPartPicker 2017-02-05 23:43 EST-0500
https://linustechtips.com/topic/733898-need-advice/#findComment-9319653
They're listing
Item Number: NMVIN
$3,099.99
$155.00 per month*
Color/Pattern: Blue
Total: $1808.03
I'm well aware its cheaper and more efficient to build your own, but did you not see where I said I cannot afford that? It will take me like 3 years to afford my own build yet with a lease after payment 1 its mine, even if I cant pay, it ruins my credit, but they won't repo the system. Its not like shitty aarons or rent a center.
CPU
https://linustechtips.com/topic/733898-need-advice/#findComment-9319943
I'm pretty sure that's going to be in the terms of service somewhere man, also certainly not worth ruining your credit to get a PC
besides only upgrading your CPU/Motherboard when Ryzen drops should be about $500 max, just throw that on credit if anything
and I suppose it's a bit late, but an FX 8 core would have probably been a better choice than the i5 for what you wanted to do
https://linustechtips.com/topic/733898-need-advice/#findComment-9319956
I never said I *would* ruin my credit, but if I couldnt pay, its not like theyd take it from me. But yes its not worth ruining it over a PC, I didnt plan too. I didn't think about that option, using a credit card to get upgrades and paying it off later, but all credit cards want a deposit. Plus it would be like what I imagine 250ish for a ryzen cpu, 100ish for the board, and maybe a vega gpu idk?
And yea I realize an FX chip would have been better at this rate, I def need more cores.
CPU
https://linustechtips.com/topic/733898-need-advice/#findComment-9320061
But ya you should still be able to stream using ReLive or just GPU accelerated stuff in OBS
Those prices should be about right for the 4c/8t Ryzen chips
https://linustechtips.com/topic/733898-need-advice/#findComment-9320069
Still not 100% sure what to do... some other people on a facebook PC group also said not to do it, they also said save it, its just for a PC of that caliber I'd be saving for years... for ryzen I *might* be able to afford it by May my birthday if I get good money from people but I'm going on 20, I doubt my family is gonna shower me in money like the good ole days.
CPU
https://linustechtips.com/topic/733898-need-advice/#findComment-9321809
