Csgo poor fps after psu swap...
Solved by SageOfSpice,
Was there any CPU overclock?
Really, the only thing that I can think of is that perhaps this new unit doesn't deliver power as cleanly which is resulting in a slight instability in the hardware.
That SHOULD reflect in benchmarks/stress testing. That's why I recommended Passmark, as you can compare to a stock version of the same processor and ensure that it's scoring as it should.
If that does turn out to be the case, I'd probably contact EVGA and discuss what should be done. Might have to RMA the PSU.
