Hey gang,
I had tried linux before and I really didn't like it because I needed to know commands to get some programs running and really I didn't want to waste my time with that. I have gotten a dell laptop for my birthday so I can study with when I'm on lunch break at work and I'm studying on Free Code Camp so my usages are:
- Browser to: study coding
                   : watch videos on youtube when I take a break
- Play around with spyder
- And maybe some program for web dev.
My issue with my laptop is that it runs pretty damn slow but loads fast (thanks windows 10) it was pretty bad when I had installed avast antivirus and then uninstalled it and it was smoother but still the response time, time to open programs and whatnot is quite slow so I'm looking for a distro that is also lightweight and easy to use for beginners and programmer friendly.
EDIT: Also would I need to reinstall some drivers from my laptop like the touchpad driver and etc...?
Thanks!
https://linustechtips.com/topic/732952-need-help-choosing-a-linux-distro/
I run mint on a 2nd box, I like it but fedora seams to be the good new one.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
3 minutes ago, Thorium00 said:
I have my eyes set on solus and ubuntu mint (not sure if I want cinnamon or mate) are they both more lightweight than W10?
yeah mint used less that 1gb of ram
Alright so I am at timmies trying to get my wireless driver to work for home because when I type in the right password it just says disconnected from internet. Im going to work soon and Ive been trying to fix it for about an hour now. Im running linux mint 18 and honestly I am already hating this but unfortunately its faster than w10. So how do I fix this problem because im checking on google and theyre asking to type all these commands and then finding this program and that program to search for driver then to type a command line *mind blown*. Last night I spent hours finding a proper tutorial to install linux if I wanted dual boot option.
So does anyone know how on earth I can make my wifi work when im connecting to a wifi with a password?
If you don't want to learn linux command line (which i would highly recommend learning it helps you know how your computer works) I would recommend either Linux Mint or Ubuntu, but I would recommend an ubuntu variant like Lubuntu or Kbuntu because unity, in my opinion, sucks.
