Hi, i have this PC and it has a 2.0Ghz CPU but in task manager it says the Max speed is only 1Ghz
What do it do?
CPU specs
Core 2 duo e4400 (Dont judge plz) clocked at 2.00Ghz
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
https://linustechtips.com/topic/732875-12-cpu-speed/
The speed reported in Task Manager is the current speed the cores are operating it, not the maximum
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/732875-12-cpu-speed/#findComment-9309924
but the CPU can NOT go higher than 2.0Ghz
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
https://linustechtips.com/topic/732875-12-cpu-speed/#findComment-9309929
1) task manager isn't reliable when it comes to clockspeeds
2) task manager was reporting your CURRENT clockspeed (the cpu drops it's clockspeed when it isn't needed)
3) get cpu-z to see the current and max
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/732875-12-cpu-speed/#findComment-9310364
