According to its specifications it supports "Liquid cooling support: Single 120mm or 240mm slim radiator"
The Nzxt Kraken has a 240mm radiator, but I'm not sure if it's also considered 'slim'.
You could try emailing NCases to ask what kind of height radiator they support max, since NZXT has the dimensions specified on their website.
https://linustechtips.com/topic/732736-does-it-fit/#findComment-9308467
from the ncase site
Sealed liquid coolers or integrated pump/block and radiator/res recommended.
Single 120mm or 240mm radiators only.
A 240mm radiator on the side bracket will prevent use of ATX power supplies or the dual 3.5" HDD cage.
Recommended maximum radiator length: 290mm (303mm available internally, however the chassis lip makes 290mm+ difficult. Utilizing the inside front 2.5" drive mount also limits radiator length).
Recommended maximum thickness of radiator+fans: 60mm (85mm total available between side bracket and SFX bracket)
so the kraken is 30mm and 26mm fans will fit no problem the rad is also 275mm so thats solved... tubes look flexible judging from reviews online
GPU drivers giving you a hard time? Try this! (DDU)
https://linustechtips.com/topic/732736-does-it-fit/#findComment-9308516
5 minutes ago, LukaH said:
from the ncase site
Thanks. It should fit since I found this on reddit
https://linustechtips.com/topic/732736-does-it-fit/#findComment-9308543
