I recently installed the cooler (CPU G4560), but I am a little bit worried, if the amount of the thermal grease, that I applied, was too much. Unfortunately, I can't evaluate the cooler and CPU from the side due to the small case. Was it too much? Should I reapply the thermal paste or leave everything as is?
https://linustechtips.com/topic/732718-too-much-thermal-paste-applied/
It's fine in my opinion.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
thats on the smaller side tbh, i would have used a little bit more but thats definatly fine
Builds:
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
Luke's explaining very well how much you should put and how you should apply and what are the impacts of each method and quantity...
as long you have more than a tiny drop, it doesn't matter
To me it looks too little. I use line method and as luke has shown, as far as u dont do too little or too much the method doesnt matter.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Thanks for so many comments!
I reapplied the paste because the performance of the first one I used was very disappointing (Spire X2-431). Therefore, I bought this time the MX-4 tube and applied it. The temperature is definitely much better this time under load - 52-54 C vs up to 70 C with the first one. However, I have a strong feeling, that this time was definitely too much paste. I watched all the videos on YouTube how to do it correctly and how much to apply, but I find it quite challenging to evaluate the amount applied. Should I try once again?
