Do you mean if the hypotenuse is correct?
'Cause it's always the longest side, which would make the example incorrect. Other than that, you just see if it equals the real hypotenuse...
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/731103-math-problem/#findComment-9289839
6 hours ago, AniJan said:
So,
how do you determine if a hypotenuse is real or not?
Example: a=4 b=5 c=2
There's no hypotenuse because it's NOT a right triangle. Are you sure you copied the right question?
No stylus needed
There is more that meets the eye
I see the soul that is inside
https://linustechtips.com/topic/731103-math-problem/#findComment-9291173
