So here's the thing.
Today I tried overclocking my R9 fury. I set the core at 1060 MHz and ran heaven benchmark. It did fine, tried again with 1090, did fine again. Finally tried 1120 Mhz on core and an additional 50 MHz on memory, figured that nothing could go wrong with all built in safety stuff and so forth. Ran heaven and just when it was finishing the run, my pc crashed, when restarting, monitor says no signal. Unplugged my card and got into windows using the iGPU on my i5 without problems. However, still no signal out of the card. I uninstalled my radeon drivers and the sapphire trixx software, thinking that maybe it was applying an unstable overclock at startup so it would crash. Monitor still not getting a signal through either the HDMI or DVI port. GPU BIOS button LED works so i guess the card is getting power still...? What to do, would really like to get up and running as fast as possible!! Thanks for reading.
System specs:
i5 6600k @ 4.6 GHz
8 gigs of Hyperx fury 2666 MHz ddr4
asus z170-a mobo
In-Win desert fox 800W PSU
generic ssd for boot and generic hdd for storage
also Sapphire nitro r9 fury
https://linustechtips.com/topic/730976-gpu-wont-output-signal/
Tbh, throughout all my ocing expierences, I've never had it completely die like that. Ive had it display nothing before, but not after using DDU (assuming you have) Might wanna check in worst-case-scenario does Sapphire allow RMA for such things? As it seems like its their problem, not yours. Of course it was ocing that caused it, but they should make their cards more stable in the first place. and not just immediately die when you try a high oc. (I got mine absurdly high on air.)
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/730976-gpu-wont-output-signal/#findComment-9288299
