Oh god the cringe.
Does flipping the PSU with fan down do anything? (assuming you can). If not, you can probably get an extension cable off of e-bay
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9286784
i see more problems here than just that cable..
that aside, you could buy an extension, or -if your case has the propper venting on the underside- you could put the power supply in fan side down, and route the cable behind your expansion slots to win just a slight bit of length.
EDIT: i just noticed that adapter on the pcie power plug, PLEASE FOR THE LOVE OF GOD, get a better power supply...
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9286787
Had the same issue when I was building a rig to sell, ended up making a diy extension using other broken PSU's. not reccomended but will work. Also if your psu cant reach your mobo then thats enough of an indication to suggest it might blow up in your face.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9286886
Guys it doesnt even reach from back side or pc.. i know it looks baad.. its my fathers pc he plays diablo 3.. pc has 960.. its enough for him. The old psu he was using making weird noises so we started using this psu.. pc got very fast when we started using this psu. Ebay takes 40 days to arrive here.. so is there any ideas about the solution.. Or im gonna cut the damn cables of psu so my father can buy a new one (if something works.. father never replaces it)
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9287163
DO NOT CUT THE CABLES, seriously that could lead to serious injury or death, and it will hurt the whole time you are dying.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9287177
dude ofc im not gonna cut da cables.. just gonna unplug da mobo cable and father be like "shit is broken"..
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9287232
This you gave me the idea so thank you "The solver of my problem" xD
https://linustechtips.com/topic/730838-cable-doesnt-reach/#findComment-9288146
