Cooler master sickleflow x120mm LED fan
Speed rpm: 2000rpm +- 10%
Air flow: 69.69 CFM +-10%
Air pressure: 2.94mm H20)
Noise 19dBA
Corsair Air Series AF120 LED Quiet Edition High Airflow Fan
speed rpm: 1500
Air flow: 52.19 CFM
Air pressure: 0.75mm/ H20
Noise: 25.2 dBa
Question: Why is the corsair air series cost more than the cooler master when the specs lost to the Cm sickleflow?  Thanks in advance
https://linustechtips.com/topic/730769-comparing-two-fan/
it costs more because corsair
  1. spent more on r and d
  2. spent more on advertising
  3. believe they are worth that much
or maybe a mix of all three.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/730769-comparing-two-fan/#findComment-9286185
personally I believe 2, and 3...
I can recommend silent wings 3 fans. From my experience, while they don't push quite as much as my noctua industrials, they are quieter doing it...Take your pick.
https://linustechtips.com/topic/730769-comparing-two-fan/#findComment-9286193
Brand name extra. Corsair is go-to atm for "gamers". So anything they make, they can put some extra. Coolermaster has quality products overall. They are widely available, which means they can lower prices in order to sell more stuff vs selling fewer higher priced stuff.
Thought, in this case Corsair seems to be better overall. Its hard to find good reviews on just fans (even when testing them should be easier compared to full heatsinks). This http://www.anandtech.com/show/6177/choosing-the-best-120mm-radiator-fan-testing-eight-fans-with-corsairs-h80/5 hints that SP120 fans would be overall better than CMs. But since you have AF fans there, and CMs might be Static Pressure optimized, they might as well be better in that match up.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/730769-comparing-two-fan/#findComment-9291721
