Need Horizontal 88W+ air cooler
Jonathan W
A.K.A. Dissapointed with AiO, back to Air!
The cooler needs to be horizontally opposed, not going to restrict my RAM height beyong reason, and keep a 4690K [88W] nice and cool at load
Hey all. So I have a Corsair H60 right now and at idle it is great, keeps everything nice and cool around 35-40C
BUT the second I max out my 4690K, even without overclocking [3.7GHz turbo] my CPU sits at a toasty 80C, 100+ if I OC.
So I've tried everything to get it cooler, my fans are on a fairly aggressive curve, I leave the panel off my case mostly, and I quadruple checked that the molex plug my pump is plugged into was getting proper power.
idk what else to do except replace the thermal compound but I used Arctic Silver and it's only been barely like a year and a half.
So i'm looking to change everything up. When I upgrade i'm getting a non-K chip, and I'm looking at Horizontally opposed air coolers because i'll be vertically mounting my rig again and wanna see that cool fan as it spins.
Looking at these coolers the "best" one seems to be the Silverstone AR06 but if I know the LMG forums, someone will have some secret one up their sleeve they can tell me about..so please do that <3
Project Hephaestus
Intel Core i5 6600K @ 4.2GHz~ASUS Maximus 9 Hero~32GB DDR4 @ 3200MHz~ZOTAC GTX 980 AMP Ed.
Those are some pretty insane temps on your 4690k - mine is OCed to 4.4ghz, and sits at around 65C under load, with not all fans at 100%, using a dark rock 3..
The reason for your disappointment is probably because single rads are pretty shit. I wouldn't get a single-fan rad AIO, ever.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
120/140mm radiators hardly challenge their air counterparts. The only time you should generally ever use one is on a GPU or if you have a really tight space and it's the best thing that fits.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
well the air cooler im looking at is only a 92mm fan
Project Hephaestus
23 minutes ago, NotTayyeb said:
21 minutes ago, Shiv78 said:
19 minutes ago, tmcclelland455 said:
For reference, the air cooler that we're trying to beat right now is the Silverstone AR06. Linus gave it his best performer medal in that air cooler showdown video.
Project Hephaestus
25 minutes ago, Name Taken said:
Have you tried delidding?
Rly. Going 0-100 real quick there... a bit of an extreme solution, which will have near to no gains too.
That's why I marked it as "funny" lol, delidding is NEVER going to happen on my system
Project Hephaestus
Depending on the chip you can get massive gains. If I had the money to replace my CPU if a delid went wrong, I could easily drop 10C+ because of how abysmal the IHS contact with the die is (based off a much hotter Q6600 on the same cooler running MASSIVELY colder at a much lower RPM).
Main rig on profile
VAULT - File Server
If you had that kind of money, you should have enough for a 280mm or 240mm AIO
HOLA NIGHT THEMERS
OTHER TECH I OWN:
I don't wanna spend 150USD+ for the "proper" AiO I should get to get good performance lol...the cost of potentially 2 new CPUs is WAY out of the question xD
Project Hephaestus
By horizontally do you mean tower with horizontal orientation or down-draft cooler? Which RAM and which case?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
By Horizontally I mean that the fan is laying down parallel to the motherboard. The case i'll be working in is the new inwin 303c when it comes out in Q2 2017 but for now i'm in a cooler master HAF EVO XB. I plan to be using full height or slightly higher than full height RAM like the GEIL EVO X or similar RGB LED RAM sticks [right now im using Ballistix Tracer Orange/Blue]
Project Hephaestus
InWin 303 (the one which is already available) has 160mm clearance, so its any horizontal/downdraft cooler. The RAM does look about same height as G.Skills RipjawX DDR3. Since you are going for looks, Noctua is out. Phanteks has PH-TC14CS with few color options. Scythe has Kabuto 3 and Grand Kama Cross 3. All three are somewhere between 120mm and 140mm tower coolers.
Thanks a ton man. The point of doing a horizontal cooler is so I can put a fancy fan there and show it off along with the other 3 fans in the vertical top portion of the case.
I've been looking at some coolers designed like the PH-TC14CS but I've been avoiding them on principal because i'm worried about the heat pipes bending over time...do you or anyone you can quote has any experience of that happening? I call that cooler design a "floating" radiator.
Project Hephaestus
Can you bend copper pipes by hand? Coolers use copper pipes with aluminium coating for the looks. Just fan isn't going to bend them that easily.
Yes I can bend Copper pipes by hand lol but you do have a good point thanks :P
Project Hephaestus
Ok. I haven't heard any such bending with coolers. Maybe there's some. But probably not in first 10 years of use.
https://www.youtube.com/watch?v=U6SRS5s625I&ab_channel=LinusTechTips
Im thinking of potentially silver glittering the cpu fan on this build with rgb led strips to try and make it look something like spinning steel to match the "Hephaestus" theme of steel and flowing lava and such...i'm looking at the noctus, the red phanteks, or the scythe kama cross 2...
Project Hephaestus
