Hey guys. I was just refining my pc parts list and I guess I could have some issues with my CPU cooler being too big.
https://www.amazon.com/gp/aw/d/B01B12DQ38/ref=ox_sc_saved_image_19?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
And the case I will be using is this:
https://www.amazon.com/gp/aw/d/B01LA2LB7W/ref=ox_sc_saved_image_14?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Sorry for being like.. Really vague. I obviously plan on overclocking. But I don't plan on water cooling right away. Does anyone even use this cooler or case anymore? I know these arent the newest and brightest,  but I like the looks of them. Or would anyone know the depth of the case?
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/730291-cpu-cooler-height-issues/
Little tip. Use product pages for information, and I'd use them for linking too. Case fits 170mm coolers which should be basically all air coolers. And Corsair is know to give few mm extra. Coolers height is 172mm, so you are really close. If you can have easy returns, why not try it.
http://www.corsair.com/en-us/crystal-series-460x-rgb-compact-atx-mid-tower-case
http://www.coolermaster.com/cooling/cpu-air-cooler/masterair-maker-8/
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/730291-cpu-cooler-height-issues/#findComment-9281149
Thank you so much!
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/730291-cpu-cooler-height-issues/#findComment-9281334
