So I've been playing with speed fan today and I was wondering. Is it better to sync the fan speed with the CPU itself? Or the core temps? My CPU stays around 37 degrees *C but my cores go well up into the 50s.
Also able to sync my bottom fan, which is the new Corsair ML120, with the GPU temps. But anyway, is it better to sync 2 120mm with core temps, or CPU temp? Is it a matter of which one I want cooled more?
AMD Ryzen 9 5950x 3.4Ghz | Asus Prime X570-Pro | Corsair Vengeances RGB PRO 64GB 3200Mhz | EVGA Nvidia Geforce 3060 XC | EVGA G3 SuperNova 750 Watt PSU
https://linustechtips.com/topic/730110-speed-fan-questions/
I would go with cores if the CPU temps are staying that much lower then it's likely an error
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279030
Error in what way exactly?
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279035
the temp sensors or monitoring software
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279038
I just HWMonitor and it's showing a different reading than what SpeedFan is showing. It looks like a software error to me. So go with core temp fan sync then?
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279044
yeah
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279048
either something is reporting the wrong temperature or reading the wrong temperature like the software or the sensor its self.  Plus there aren't many cpu's that run at 37c full load
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279052
1 minute ago, GDRRiley said:
yeah
That's pretty odd isn't for Speed fan to show the CPU and the core at different temps? Is there a way to fix that?
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279056
no
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279059
How do I check? Speed Fan is reporting one thing, and HWMonitor is giving me a more correct reading.
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279064
HWmonitor is more likely to be correct in my experience, I used to use speedfan a lot and there were always some sensors that didn't read/report correctly.  Something about the differences between motherboards and I don't think that speedfan really officially support most motherboards.
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279087
That's a shame because I do like using it since Asus hasn't update IA Suite 3 since windows 7 and now 10. So it was my only other best option. At least it's reading the core right which is fine because it doesn't make sense for the 2 top fans being useless not doing what I put them there to do. xD
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279154
it will work with most motherboards, especially asus it seems.  It's really just the sensors and some of the other features that can be buggy or not work 100% correct.  Still a great piece of software though!  Using the cores shouldn't have any negative effect other than you'll have to create a fan curve for each core
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279170
I based both fans on core 1 since it changes temps at the same time as the other cores do. That should be ok right?
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9279223
That's fine. There usually isn't much of a difference in temps between the cores.
There's also the option to sync fan speeds to multiple temps. I would personally sync exhaust fans to cpu and gpu temps and leave intakes at a set speed.
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9280363
Thanks, I'll see what I can do, and set it to my needs! Thanks for your help!
https://linustechtips.com/topic/730110-speed-fan-questions/#findComment-9280384
