My brother in law asked me how much it would cost to build or purchase a pre-built PC for using Autodesk Inventor. I have been looking at forums and such and have not found any consistent answer as to specific recommendations. I have a good amount of experience with building gaming PC's but not much experience when it comes to workstation PC's. I have reason to believe he would need at least an i7 (product page says single core performance is most important) with a decent amount of ram. When it comes to graphics cards I am not completely sure what he would need. Any thoughts and help are welcome!
https://linustechtips.com/topic/729477-need-help-on-new-build/
Ok, We need a budget for 1.
2. i7 have MORE cores and not necessarily better single core performance.
3. Is it only for cad? or will he be doing more things.
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272759
Actually, it usually does mean better single core performance. You forget that each core on an Core i7 has two threads due to hyperthreading, rather than one. One physical core, and an additional 'logical core', or a hyperthread.
Only a radical difference in either clock speed or architecture (or both) will have a Core i5 beating a Core i7 CPU.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272782
The reason I built my main system was initially for autocad and inventor, so I can definitely recommend either the i7-6700k or i7-7700k. You don't need a 6 core CPU. The 4 core 8 threads with hyper threading gives crazy good performance. But you are correct you will need a decent amount of RAM. I recommend 16GB minimum and 32GB if its in the budget. As far as graphics go you really don’t need much at all, my system has a GTX 960 4GB, I think the new GTX 1050 Ti’s are comparable. And that’s more than good enough. This being said you may want to wait for Ryzen to come out. AMD might take top spot for performance, and hopefully will be a bit more wallet friendly than Intel while doing so.
I’ll attach my review of the i7-6700k, that could help you.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272806
1. Not sure on a budget. He asked for a price and I didn't know for sure what he would need. Nothing absurd I would say.
2. 7700k has the best single core performance
3. Only for CAD and internet browsing
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272808
Thank you! This is what I was looking for! I assumed I would probably tell him to wait a little while until we at least knew what Ryzen would be capable of and pricing.
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272816
Here is my i7-6700k review, this would apply to the new i7-7700k as well:
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272820
@Simonsez1337 I just quickly threw this together as a potential i7-7700k build, not sure on your budget but this is in CAD$: https://ca.pcpartpicker.com/list/FV6fD8
So that has a big air cooler so you can overclock, a good Micro ATX board meaning you can have a smaller case, a good GTX 1050 Ti GPU, 2x8GB DDR4 RAM which is the minimum I'd recommend as cad uses lots of RAM (I have 2x16GB sticks in my build), a semi-modular 650W power supply for some future proofing if he would ever want a beefier GPU, and two 525GB SSD's that in raid 0 would be very reliable and fast (only a suggestion my system has my OS and program files on one 256GB SSD, with everything else on much cheaper hard drives)
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/729477-need-help-on-new-build/#findComment-9272896
