Finished build, what next?
Go to solution Solved by Guest,
MSI Afterburner with Riva tuna
3D Mark to benchmark it
Steam and origin
Here's my part list https://pcpartpicker.com/list/NrMqr7
I've set up my drivers and made sure everything's up to date, but what software should i be using to make for a better experience? I have NZXTs CAM to monitor my system and Avira antivirus but I do not know what i need yet. I have a 1 TB HD not on the list btw
Edited by GenialGiraffe
I'm using this for gaming and rendering animations, I was referring to software like MSI afterburner
https://linustechtips.com/topic/728932-finished-build-what-next/
Play games.
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267176
So you built the computer but don't know what to do with it? Why the heck did you build it?
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267233
One antivirus program is not sufficient.  You should also add Malwarebytes for malware protection.
Next step is to lock down Windows 10 spying.  Don't ignore this step!  No matter how many windows settings you disable, Microsoft is still spying a LOT more than you think.  At a bare minimum, you need to install Spybot Anti-Beacon.  For more info, Barnacules Nerdgasm and Crit have done some really great videos on the topic!
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267280
Why is everyone so concerned about Windows "spying"? Microsoft doesn't care about what you use your computer for, data gets anonymously collected and analyzed as a larger set by a computer. No data collected gets individually analyzed by humans, and all of it is anonymous. If spying is really this concerning, throw out your phone, credit cards, car, tv, etc.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267389
agree
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267444
It's because they didn't ask and that level of data collection hasn't been present in an operating system before. The amount they "spy" is significantly more than anything before and they made it very difficult to turn everything off.
The part that pissed me off was that they didn't even MENTION it during the install, at least not everything. I had to find about it later.
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267715
Its still nothing relevant. It isnt like there is some Microsoft employee sitting at a desk somewhere watching your every move on a computer. You can read Microsoft's statement here - https://privacy.microsoft.com/en-us/privacystatement. None of the data they collect is anything unreasonable. None of it gets handled by actual people. Google has been doing most of this stuff for years.
https://linustechtips.com/topic/728932-finished-build-what-next/#findComment-9267931
