So I'm building a custom loop and I was wondering how I get white coolant, do I buy white coolant or do I mix clear coolant with white dye? this is my first custom loop so I'm pretty clueless when it comes to liquids, anyone know a good brand for white coolant or good white dyes?
I'm using EK Waterblocks X360 Extreme custom loop
I'm from UK, so has to be available in UK
Also, can someone explain why I need to use distilled water? does it have to be specific distilled water or any?
Gaming Rig:  Case: Modified  NZXT H440 Black/Red | Storage: 512GB Samsung 960 Pro SSD & 3TB WD Black HDD | CPU: Intel Core i7 7700K | Motherboard: Z270 Sabertooth TUF Mark 1 | PSU: 1000W EVGA P2 | Graphics Card: GTX Titan X Pascal | RAM: 32GB G.SKILL Trident Z RGB 3600Mhz | Cooling: X3 RES, CoolStream XE 360 Rad, Gold EK Supremacy EVO, D5 PWM EK Pump, Ice Dragon Nano Fluid 2Litre | Fans: 6x Corsair SP120 PWM Fans 1x Corsair AF 140 | Cables: CableMod Black/Red Braided cable kit | Case Mods: Tempered Glass front panel & Tempered Glass Side Panel (Finished)
Setup: Monitors: Ben XR3501 2x Acer GN246HLBbid 24 | Keyboard: K70 & K95 Vengeace RGB Cherry MX Red | Mouse: Razer Deathadder & Corsair Scimitar RGB | TV: 43" LG 4K Smart TV, 50" Samsung 4K
Laptop: ASUS ZenBook UX310UA-FB097T
Racing Cockpit Setup  GT Omega Pro with TV stand | 52 inch Bush Smart TV | Fanatec CS v2.5 | Fanatec CSL Elite LC | Fanatec P1 & Formula Rim | Corsair Strafe Blue MX RGB
Racing Cockpit PC: Case: Unknown cheap case from Amazon (modified to fit GTX 1080 & Cooler) | Storage: 1TB Samsung 960 Pro | CPU: i7 7700k | Motherboard: MSI Z170 | PSU: 750W EVGA Gold | Graphics Card: GTX 1080 | RAM: HyperX Fury 32GB 2400mhz | Cooling: Hydro 100i | Fans: 4x Corsair SP120 PWN fans | Cables: Standard PSU Cables | Case Mods: Making room for GTX 1080 & Cooler.
https://linustechtips.com/topic/728904-custom-loop-white-coolant/
Get some mayhems coolant.
You can do both ways, I prefer premixed so that I don't need to worry about distilled water and measuring stuff.
Is Mayhems coolant ready made? like just fill and forget? I don't need to mix anything with it?, also I've looked at Mayhem and they don't do White coolant?
These are concentrates
https://mayhems.co.uk/coolants/pastel-coolants/pastel-extreme-100ml/
https://mayhems.co.uk/coolants/pastel-coolants/pastel-concentrate-250ml/white-250ml/
And this is the premixed
https://mayhems.co.uk/coolants/pastel-coolants/pastel-pre-mix-1ltr/white-1ltr/
Also check out their Ice Dragon nano white... solid product by most accounts, and good longevity. I've just bought some myself but not used yet.
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
