I need a case fan for my s340 case. It will be mounted on top side.
I also have 2 x 140mm cooltek fans for intake working at 900 rpm.
I have found a noctua 140mm fan at 900rpm that is very silent.
Should i go with it?
https://www.amazon.com/Noctua-Bearing-Cooling-NF-P14s-redux-900/dp/B00KF7NGUE
https://linustechtips.com/topic/728872-case-fan-for-exhaust/
Noctua, SilentWings3...
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/728872-case-fan-for-exhaust/#findComment-9266453
either that or an ml-140 fan from corsair
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/728872-case-fan-for-exhaust/#findComment-9266454
Be Quiet pure wings if your budget is less than $15. I personally wouldn't get Noctua because it would ruin my color scheme (not bashing the fan quality, just looks).
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/728872-case-fan-for-exhaust/#findComment-9266530
