26 minutes ago, cc143 said:
To my knowledge sigma do make several lenses which are not FF compatible, such as the 18-35 art, a great lens, that won't work as far as I'm aware on a FF sensor. That said, shouldn't the adapter work? unless they use the EF mount but make only APS-C sized lenses...
Sigma DG lenses are meant for full frame
Sigma DC lenses are meant for cropped sensor, APS-C
Sigma DN lenses are for Mirrorless
The EF to E mount adapter by Sigma is primarily meant for people to mount Sigma lenses designed for Canon bodies to be used on E mount bodies (i.e. Sony E mount cameras).  It shouldn't matter if the lens is designed for full frame or cropped sensor.  Of course if you mount a Sigma DC lens using that adapter on a Sony A7 series full frame, there would be serious vignetting.  If you tried using a Canon brand EF lens with the Sigma adapter, it may have compatibility issues.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
1 hour ago, AkiraDaarkst said:
Yeah I corrected myself about the price.  It's only meant to be used with Sigma's own lenses.
Well I need something for canon lenses. I don't plan to switch to sigma.
Correct. They do make APS C lenses like the 18-35 1.8. However they use the EF mount, and can be mounted on FF Canons, although with very strong vignetting.
It can work with quite a few canon lenses really well. But only the EF ones. EF S ones can be used by cutting off the extra bit of plastic used to make it EF S, but that's dangerous and will void the warranty. I've seen someone use the 55-250 using that method.
CPU: Ryzen 7 5800x + H150i Elite LCD
RAM: 32GB Corsair Vengeance Pro RGB DDR4 3600MHz CL16
Motherboard: Gigabyte X570 Aorus Pro
GPU: MSI RTX 3070 Ventus 3X OC
SSD 1: Corsair MP600 1tb (Windows)
SSD 2: Samsung 840 EVO 120gb (Scratch Drive)
SSD 3: Samsung 860 EVO 250gb
HDD 1: WD Blue 1TB
HDD 2: Seagate Barracuda 2TB
Case: NZXT H710
PSU: Corsair TX750M
Mouse: Lamzu Atlantis Pro Mini 4khz
Keyboard: Akko 5075B Plus
OS: Windows 10 Pro 64-bit
6 hours ago, AkiraDaarkst said:
FYI, Sigma makes a Canon EF to Sony E mount adapter that's meant to work well with their own Sigma lenses for Canon mount.  The adapter is relatively cheap.
Yep, however the LA-E3 adapter is cheaper I think or at least similar in price and will not only give the option to use Sigma lenses but also all A mount lenses with a built in AF motor. So in that perspective sonys own adapter seems to make more sense to me.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
Yes, a Sony to Sony adapter that's designed by Sony is probably the most certain way to avoid any compatibility issues that might pop up with third party adapters.  But Sony lenses can be pricey, and if one has already invested in Canon lenses...
A mount lenses are still expensive compared to canon EF S.
Yes, as the sigma adapter can be used on quite a few canon EF glass, and some efs glass with the cut the end off trick.
HDD 1: WD Blue 1TB
Case: NZXT H710
PSU: Corsair TX750M
