Why are webpages taking relatively long to load?
Wierzbak
Hey, can somone explain me like I'm five, why are webpages taking relatively so long to load? Like some pages (and I mean legit, big websites) can take even 4-5 seconds to load? How much do they weigh? I'm rolling around 600-700 Mbps fiber connection, and I'd expect surfing the web to be similar experience as browsing files on a SSD.
It could depend on what browser you use. I personally found that Chrome tends to have the best luck when it comes to massive amounts of data rolling through.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (9TB partition for general storage + 2TB partition for dumping ground), 4x 8TB WD White Label/Red (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
That's what I'm using. And if not for the sychronization and other stuff I use, I would jump to any other browser, even Edge. Chrome tends to freeze and crash with ~10 tabs open (most of it is YT) and then searching through video. Or when refreshing facebook. Or when doing pretty much anything a bit more intensive. It drives me nuts lately.
*sitting here with like 10Mbps*
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
Use Internet Explorer
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
Will it really fix my problems, or you're just trolling? :D
Image result for internet explorer meme
Sorry I had to troll lol. But personally I'VE never had any problems with it
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
As much sour taste as this comment will get, Microsoft's Edge is supposed to be much faster than both Chrome, and Firefox.
13 minutes ago, Dawson Wehage said:
BadLuckBrian
LMFAO
1 hour ago, RIris said:
LMFAO
Well there is many reasons sure
Corsair 4000D RGB
AMD 5600x3d
32gb 3200mhz gskil
you do know with Trump becoming President the isp's are going to have their way and net neutrality will be no more if the new administration gets away with it. that means throttling by the isp's in hopes of making people pay more for something they already had............. and the slow ups are a precursor.
Thankfully this doesn't apply to me, as I live in Poland :P
remember this from above............ global spy initiative. don't you guys get any news in Europe? the pornography must be great over there. stop letting yourself get distracted.
I've got one question for you, are you running IPv6? If so, I can tell you that by default IPv6 web pages will take slightly longer to load due to the security and other overhead associated with the protocol that IPv4 doesn't have built in.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
How do I check this? I'm a complete moron when it comes to networking, I'm more of a hardware guy :P
If you go to http://test-ipv6.com/
it will tell you if you can do IPv6 and what the default is for you (IPv4 or IPv6)
Prior Build Log/PC:
Quote
Your IPv4 address on the public Internet appears to be 150.254.191.217
Your IPv6 address on the public Internet appears to be 2001:0:5ef5:79fd:38ed:3913:6901:4026
Your IPv6 service appears to be: Teredo
Your Internet Service Provider (ISP) appears to be POZMAN POZMAN-EDU, PL
Good news! Your current configuration will continue to work as web sites enable IPv6.
You appear to be able to browse the IPv4 Internet only. You will not be able to reach IPv6-only sites.
Your IPv6 connection appears to be using Teredo, a type of IPv4/IPv6 gateway; currently it connects only to direct IP's. Your browser will not be able to go to IPv6 sites by name. This means the current configuration is not useful for browsing IPv6 web sites. [more info]
Your DNS server (possibly run by your ISP) appears to have IPv6 Internet access.
What does it mean?
It means you have IPv6 enabled and are using it by default, which is expected.
If you go to Network and Sharing Center > Change Adapter Settings (on the left hand side) > Right click on the Network Adapter > Click on Properties > (at this point you should see Internet and Internet) > Click Properties at the bottom  > Uncheck the box next to 'Internet Protocol Version 6' > Try to browse to a different page you haven't gone to before and let me know the results.
Prior Build Log/PC:
I did it, it looks like pages are loading a bit faster now, but I'm not sure if that's not just a placebo :P
Yah, lets try this.
Start > Run > CMD > ipconfig /flushdns
Then try to browse to a site and see. That will flush all the DNS entries on the computer and make the computer request the addresses again, fresh, so we'll know for sure.
Prior Build Log/PC:
You could try changing your DNS server, sometimes the ISP ones are not so good, so more and more people now use google or openDNS servers. Go to your router's webadmin page and look for "internet" settings, then find the part that says Domain Name Server and change the setting to either 8.8.8.8 and 8.8.4.4 for google's or use 208.67.222.222 and 208.67.220.220 for openDNS. Click apply and you're done.
If you're not fluent with this stuff, make sure to backup your settings in case of mistakes.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Sadly I don't have access to router. I live in a dorm, and plug my computer "to the wall". Router is somewhere in the basement I guess :D Also, I can sometimes play music on sombody's computer through spotify, as we are all connected to the same network :D
Ahh I see, in that case you can "force" the DNS addresses by in your computer going to network and sharing center (right click network icon)
Click on your adapter (in blue), a new window will open.
click on "properties", new window will open.
"select" - don't un-tick, where it says "internet protocol version 4" and again click "properties"
Click on the little round button where it says "use the following DNS server addresses" and enter the info I gave you previously., then click OK. Then you can close the other windows and you're done.
You can test what you're using on the same window we first opened up "status window" after we clicked blue highlighted text, by clicking the "details" button.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
