Why are webpages taking relatively long to load?
Wierzbak
Okay, I swapped to Google's DNS. I will tell you if it's any better after a few days of use ;) Thanks a lot!
48 minutes ago, Wierzbak said:
I live in a dorm,
Answer to your question right there.  Everyone else is using the bandwidth to look at porn, so when you try to load porn it takes longer.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
That's not the case, I'm downloading files at ~50 - 60 MBps
