Hey so I'm new to pc building and I did research on what to buy and all. I bought everything and plugged it in into my motherboard. When I was done plugging everything in I pressed on the POWER SW.
All fans started blowing and my gpu started lighting up. So I thought I did everything correctly. When I went to the assigned HDMI-channel it showed me I had no signal. So I looked up on youtube on how to fix this problem. They told me to remove ram clean it and tried all the 4 slots on my motherboard. No luck. Another fix was to unplug the gpu and look if your gpu is broken or not and I plugged the HDMI into the MoBo. Still no luck. Another fix was to remove the circle shaped battery for 5-10 mins.  and then put it back in. I did         but still no luck. I even unplugged everything except psu and the power cords that were needed to turn on the PC and started plugging my parts one by one into the MoBo but even that didn't help resolve my problem. So this is a cry of help to anyone who knows how to fix this.
Specs:
i5-7400 Processor
RADEON GIGABYTE RX 470 GPU
Corsair VS550 PSU
Cooler Master 212 EVO
Samsung 120 GB SSD
Toshiba 500 GB SSD
Crucial DDR4 8GB RAM
B150 PC MATE MoBo
https://linustechtips.com/topic/725451-system-wont-boot-up/
i see you have an 7th gen i5 and your mobo was made when there was only the 6th gen. your bios will probably need an update. do you, or a friend of you, have an 6th gen cpu?
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/725451-system-wont-boot-up/#findComment-9228634
You have a B150 Motherboard and a Kaby Lake CPU. B150 (just as H170 and Z170) doesn't support Kaby Lake natively, even though they share the same socket. You need to update your BIOS first in order for your Kaby Lake CPU to work.
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
https://linustechtips.com/topic/725451-system-wont-boot-up/#findComment-9228640
This is the BIOS update you need download.msi.com/bos_exe/7971vCA.zip
You will however need a 6th gen CPU to update the BIOS itself.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/725451-system-wont-boot-up/#findComment-9228692
