*i don't know where i should make topics of temperature so i made it here*
So i have an FX-8320 OC to 4Ghz(using CM hyper 212X) and a Zotac gtx 660ti Amp edition.
the temps when both at idle are in the low 40C and high 30C.
but when at load, the CPU barely reaches 60C max and my GPU is running at the 70C.
i can load my system full burn without any error but i want to know if
these temps are ok? and also, my gpu RAM modules doesn't have any thermal pads/heatsink on it, is this ok/fine?
I know this isn't a problem or troubleshooting related but i really need to know if this is ok because i mostly use my pc 24/7 without it turning off.
When 2 things meet each other, Quantum stuff happens.
https://linustechtips.com/topic/72533-are-these-temps-ok/
Those temps are good.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/72533-are-these-temps-ok/#findComment-993522
Yeah no problem. For aircooling that is. I have an i5, which is currently ideling at about 45C and my GPU is 35C, GTX660. When I put it under heavy load both go up to max 80C each, GPU usually a bit lower.
And when I play games the GPU goes to about 65C. So you are running fine.
YOu should start worrying when they go above 90C.
"Great minds discuss ideas; average minds discuss events; small minds discuss people."
Main rig:
i7-4790 - 24GB RAM - GTX 970 - Samsung 840 240GB Evo - 2x 2TB Seagate. - 4 monitors - G710+ - G600 - Zalman Z9U3
Other devices
Oneplus One 64GB Sandstone
Surface Pro 3 - i7 - 256Gb
Surface RT
Server:
SuperMicro something - Xeon e3 1220 V2 - 12GB RAM - 16TB of Seagates
https://linustechtips.com/topic/72533-are-these-temps-ok/#findComment-993970
90C and above is acceptable for a GPU. Not a CPU.
https://linustechtips.com/topic/72533-are-these-temps-ok/#findComment-994806
Yeah you are right, safe temp for CPU is about 70C. My bad
Main rig:
Other devices
Surface RT
Server:
https://linustechtips.com/topic/72533-are-these-temps-ok/#findComment-995839
