Android OS Contacts Bug? Same Entry on Two Lines
Go to solution Solved by crumbworks,
It wasn't display related. I ended up removing all her "accounts" (Google, Whatsapp, Skype, etc) and re-adding them, and that did the trick. Something glitched and that's the only thing that fixed it up.
I'm trying to fix my mother's Android phone (Nexus 5 with Android 6.0.1)
Half a dozen contacts are showing up twice but they are NOT duplicates -- meaning:
- if I highlight one of them to select it, it highlights both lines
- it detects I'm only highlighting 1 entry (says so at the top), even though it has a checkmark on both
- there's no "merge" button because, as I said, it detects it's a single entry I'm highlighting, not 2+ (it's simply listing it twice)
- It only shows the merge icon up top if I select a DIFFERENT contact along with "Marc" (using example below), because then it realizes two are being selected
- I even exported the Vcard and it also shows the entries only once
- Same thing on Contacts via computer -- the entry is singular
- Yet her phone shows those particular people on two lines
- Any tips / suggestions? I've crashed Contacts app, cleared cache, rebooted phone, etc.
See screenshot
Core i5 750 | 8GB DDR3 | R9 270X | Intel 520 SSD | ASUS 24" 1920x1080
Have you looked at contact display options?, might be displaying both SIM/phone or SIM/google etc.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
