So my PC was previously Woking all fine until it randomly began to turn off and back on by itself and it turns out the 24 pin connector wasn't fully plugged in so I pushed it in until it clicked and I thought it was ok I then just booted it up and I can't power down via the power switch button nor is it showing video any help would be appreciated
https://linustechtips.com/topic/724548-help/
So today I built my PC as I just got my graphics card for Christmas but had already saved up for the rest. This is my first build and a pretty stressful one. So I built the PC in around 3 hours then spent the last cable managing to find that the PC simply wouldn't boot I was confused for the next 3 hours after this and dreading that I had just wasted all my money. Eventually I got it to work and everything was all good I then had an issue with it randomly turning off but have seemed to have fixed it. I have now tried installing the OS from my usb and everytime around 50% I would get an error code I reinstalled the os onto my usb and tried again same error could anyone help with this as I would like to have my PC running hopefully by tommorow I get the error 0x8007025D thanks in advanced.
https://linustechtips.com/topic/724548-help/#findComment-9218133
4 minutes ago, Muzzy2002 said:
Wait is it the silver circle?
yes
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/724548-help/#findComment-9218242
13 minutes ago, Muzzy2002 said:
How do I remove this it has a little silver latch type of thing in the side
16 minutes ago, RadiatingLight said:
yes
27 minutes ago, frozeNNN said:
It's usually under first pci-e slot,take the baterry out for few minutes (first take the power cable out)
https://linustechtips.com/topic/724548-help/#findComment-9218322
