Single 165hz 1440p Ips G-sync monitor Or 4k Ips monitor + 144hz monitor?
Solved by HKZeroFive,
Depends on your workload or priorities.
Gaming? The Acer XB271HU all the way - the combination of the high refresh rate, IPS panel and G-Sync makes it a fantastic monitor. I myself have the similarly specced ASUS PG279Q and it's great.
Productivity? A two monitor setup should help with your workflow and the higher resolution of the 4K monitor might help if you're dealing with things like photo or video editing.
