6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/
they usually do (not gonna say that as a reassurance, because you're never really sure about chinese stuff) but they feed your GPU with so little bandwidth they're essentially a guaranteed bottleneck on anything better than like some GT640 :P
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210191
seems like a good idea for if you need multiple monitors
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210219
They probably work, but keep in mind that the miniPCIe has only ONE pci express lane, which means maximum 500 MB/s in both directions for PCIe 2.0 or almost 1 GB/s for PCIe 3.0
This will be a serious bottleneck for higher end cards, the maximum fps will be quite limited.
The razer solution uses more pci-e lanes and higher throughput, uses more expensive cable between laptop and external case etc.
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210229
ehh.. there's better solutions, this is a terrible, terrible bodge that essentially turns a laptop into some frankenstein bodge that's rotting away in front of you.
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210244
yea and I bet for most laptops this would mean sacraficing wifi
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210246
so just like my laptop thenxD
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210250
my laptop is held together by glue and prayer hoping the nvidia chip wont randomly disappear again.
that's less of a bodge than what these disasters do.
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210267
ah mine is holding the hard drive in with blu tac, the laptop is so old the cpu is still in a socket and not soldired
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210286
that's not old, that's a well made laptop.
in fact most high end laptops have socketed procs :P
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210290
ah so 10 points to the celery T3300
PSU tier list-
https://linustechtips.com/topic/723859-do-these-adapters-work/#findComment-9210293
