Hello, I need a new monitor for my gaming setup the features it needs are as follows.
- WQHD / 1440p / 2560 x 1440
- 60Hz to 144Hz Refresh Rate
- 1ms - 3ms Response time
- Thin Bezels
- Under £380 (GBP)
- 27" (27 Inch)
- Thanks, Jamie
Edited by Jamie_Taylor_4200
https://linustechtips.com/topic/723847-i-need-help-please/
- FHD / 1080p / 1920 x 1080
- 144Hz Refresh Rate
- Thin Bezels
- Under £300 (GBP)
- Thanks, Jamie
I can't think of any off the top of my head with those requests, hmm, gimme a minute
Yours faithfully
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210056
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210058
You see, that's a bit hard cause there are very, very little monitors with an IPS Panel and that quick of response time
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210060
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210082
1 minute ago, Jamie_Taylor_4200 said:
i don't want an ips
in that case Asus VG245/248
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210089
2 minutes ago, Jamie_Taylor_4200 said:
I can go up to £320 if that helps
anything higher in price than the 27" I listed would be 400 gbp
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210100
Response time in that sense means very little, and will have no impact on your experience.
Have a quick read of this:
Specifically the "response time and latency" section.
Hope this helps :)
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210102
https://linustechtips.com/topic/723847-i-need-help-please/#findComment-9210117
