Screen offset?
Go to solution Solved by Slottr,
Have you tried turning it off and back on again
https://linustechtips.com/topic/723644-screen-offset/#findComment-9208011
6 minutes ago, LucasDerpYT said:
Just did, it worked.
So this is solved?  You can mark Slottr's post as solved then with the checkmark :)
https://linustechtips.com/topic/723644-screen-offset/#findComment-9208103
