AOC Monitor
Bruno_A
Hey guys, I recently bought an AOC 1080p monitor and watched some unboxing videos of it and noticed there's different versions of the product, some have HDMI, some don't and some only have VGA, so, if I'm getting the version with the VGA port only, what can I do? I'm going to connect it to a GTX 660. I know that there's HDMI to VGA adapters, but are those the same as an HDMI to HDMI connection? I mean, is there any loss of "signal" or color, etc? Here's my monitor: AOC E2270SWN.
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
I don't think VGA can push 1080p 60hz...  VGA is an analog signal so you'd need an active HDMI converter.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
analog signals usually cant carry the same kind of color information as a digital signal, thats usually the only real downside of using it.
if anything since its a TN panel you wouldnt be missing out on much- you can always tweak the color setting on the monitor to suit your preference
can you still return the monitor?
Photography / Finance / Gaming
Wrong. VGA is able to do 1080P 60Hz. It becomes blurry though.
To the OP. I would not go the route of HDMI to VGA. The adapters have been known to be really bad, and most times for me straight up don't work. According to the AOC site, that model is VGA only. I would chose a different monitor. Are you able to switch it out?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
I purchased the monitor in a 20% sale, and just contacted the shop and there's no way they'll change my order without losing the 20% off...
