Hey all, iv had a problem recently where despite removing the cpu slot, the cpu is still ramping up and working at ~100% load.
I have reinstalled and tried fiddling with slots. But to no avail. Is this a known bug? Or am I missing something.
Not it that I also added abscond GPU without drivers, if this has something to do with it. And I'm being ignorant.
Many thanks.
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/720230-fah-wont-stop-using-cpu/
1 minute ago, tobben said:
Have you found the actual process in the
task manager? are you sure it's folding
that is ramping up your cpu? is this on a
desktop or laptop?
I will double check these things tonight, after classes. Thanks!
It starts in time with when I hit folding. So I haven't thought of checking. Also, it's on desktop.
https://linustechtips.com/topic/720230-fah-wont-stop-using-cpu/#findComment-9169789
desktop or laptop?
Hello again, So i'v looked and have confirmed that its FaH using the cpu.
Also my gpu is not working despite the controller stating that it is. Wattman gives no activity. Although FaH lists it as Ellesmere XT (rx480). Funny thing i noticed.
Again, I did put in a second GPU (660) to run fah at the same time, but it has no drivers. I dont know if its possible that it is causing all this or it save to leave to in.
https://linustechtips.com/topic/720230-fah-wont-stop-using-cpu/#findComment-9173296
In hindsight i kinda expected this, i've seen
it before :P
You could try changing the opencl index on
the first slot, to either 0 or 1 depending on
what it is now, see if it does anything. And/or
the gpu index to get them to match. I would
guess that fah might be mixing them up, can
get it wrong when mixing gpus.
To be honest, i don't know what problems it
can cause when you haven't installed any
drivers either. But, i have seen the same
problem from driver issues before.
So i would guess that either A) You have
very outdated drivers on the 470, and you
need an update, or B) fah is mixing up the
indexes and trying to fold on the wrong gpu.
Updating drivers, or pulling out the second
gpu is probably the easiest/quickest to try
first. Just by process of elimination, then you
might know what the problem is.
https://linustechtips.com/topic/720230-fah-wont-stop-using-cpu/#findComment-9175106
