So this is my current setup with my PC and Xbox One on the floor. When I upgrade my PC I want to do things like full loop water cooling in my PC and even maybe try a small form factor PC or make it bigger (It's micro ATX right now). If I get a side window for my PC I would obviously like to display its internals but if It's on the floor and won't fit on my desk what are some things I could do to display it? or make the setup better in any way? thanks
https://linustechtips.com/topic/719222-help-deciding-system-placement/
Small form factor and watercooling? Fractal design nano S and that should fit on your desk pretty easily :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Just now, ripper101 said:
Can you make a quiet water cooled PC with that much space?
Ermmmm...not quite? (unless you're willing to trade thermals for noise as after all, you can only fit a thick 240mm rad in it...)
How many radiators should I need to have a quiet system with 1 cpu and 1 gpu in the loop
the PC could sit on the right side of the desk with mic clamped behind the monitors and hovered over. That way you could fit a full tower on there
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
