Hello guys,
My question is very simple, is there a shop out there where I can buy a SATA Data Y-cable?
Just to stop you guys from telling me, that I can't connect two drives to one SATA port on my mainboard, I have to tell you, that I know that. I do not want to connect 2 drives to one SATA port or the other way around.
For the project I am working on, I need to access one drive for 2 different devices, but not at the same time. I just want to use the drive with the one device, when the other one is turned of without switching the cable.
https://linustechtips.com/topic/719207-sata-data-y-cable/
I don't think it exists because A: it would cause a lot of confusion because it's not designed to work like that and B: you are probably one of the very very few people that need such thing.
I do however have some alternatives:
Hot-swap bays, just move the HDD between bays if you have to.
Network share, attach the drive to your network on one of the pc's or a seperate dedicated pc and use network shares to get to it.
Apart from that, don't really know any decent alternatives...
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/719207-sata-data-y-cable/#findComment-9159204
