Monitor and TV .. different resolution at the same time
Omxp
Hello all .. I have a tv and 4k monitor, I want to have a different resolution for each device, because 4k resolution look way too small on tv and when I choose 1080 it look zoomed on the monitor!! how can I fix this issue and have the best resolution for each device? I don't extend displays at all.
thanks
You can't mirror them perfectly. You can extend them.
So I have to change the resolution on each display every time I use it too look perfect?!!
that is not cool at all.
thanks
Radeon Software supports mix and match of different resolutions, give it a try if you're running an AMD card
thanks
Well if you want to show the same thing on each (mirroring), then it makes sense need the same resolution.
Current LTT F@H Rank: 90    Score: 2,503,680,659    Stats
Yes, I have 9 monitors.
My main PC (Hybrid Windows 10/Arch Linux):
OS: Arch Linux w/ XFCE DE (VFIO-Patched Kernel) as host OS, windows 10 as guest
CPU: Ryzen 9 3900X w/PBO on (6c 12t for host, 6c 12t for guest)
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 32GB G-Skill Ripjaws V @ 3200MHz (12GB for host, 20GB for guest)
GPU: Guest: EVGA RTX 3070 FTW3 ULTRA Host: 2x Radeon HD 8470
PSU: EVGA G2 650W
SSDs: Guest: Samsung 850 evo 120 GB, Samsung 860 evo 1TB Host: Samsung 970 evo 500GB NVME
HDD: Guest: WD Caviar Blue 1 TB
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Other: White LED strip to illuminate the interior. Extra fractal intake fan for positive pressure.
unRAID server (Plex, Windows 10 VM, NAS, Duplicati, game servers):
OS: unRAID 6.11.2
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
GPU: EVGA GTX 1080 FTW2
PSU: EVGA G3 850W
SSD: Samsung 970 evo NVME 250GB, Samsung 860 evo SATA 1TB
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity)
Case: Sillverstone GD08B
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Details: 12GB ram, GTX 1080, USB card passed through to windows 10 VM. VM's OS drive is the SATA SSD. Rest of resources are for Plex, Duplicati, Spaghettidetective, Nextcloud, and game servers.
