What's the newest, latest, best way to apply the cold goo
CPU: Intel i5 3570k @ 4.0Ghz GPU: EVGA 660 SC - Awaiting Gigabyte 770 HOF MOBO: Asus p8z77-V Pro PSU: Corsair CX600 - Awaiting Corsair RM850 Storage: 750GB Seagate SSHD + 500GB HDD - Awaiting 250GB Samsung 840 EVO RAM:  16GB ( 4x4GB ) Crucial BallistiX Sports - Awaiting Crucial BallistiX Tracer 16GB Kit Case: NZXT Phantom - Awaiting Undecided Upgrade CPU Cooler: NZXT Havik 140
https://linustechtips.com/topic/71770-thermal-compound/
I don't think application method has changed much. Dot in the middle and let the cooler do the spreading. Subject to opinion though.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982657
Just apply a pea-sized amount, and let the mounting pressure do the work.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982661
ICDiamond or Artic MX-4 is one of the best. The difference will be a few degrees. Pea sized drop on middle and let it spread automatically by the cooler pressing on with the cpu.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982662
Line, pea, spread--doesn't really matter. There's a reason why it's still being argued.
The amount you use matters more than how you apply it.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982665
Use the full tube, and make a nice, 3mm thick line all the way around the outside edge of the CPU.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982672
spread method makes air bubbles air bubbles are bad, pea shaped not sized dot in the center and let the cooler spread, line is acceptable too.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982719
I use the grain of rice method with Noctua NT-H1. Works really well.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982726
I ordered 1.5 grams of IC Diamond, how much should I apply?
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982729
a dot <= to the size of a pea in the center of the cpu.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982742
A pea or uncooked grain of rice amount.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982750
The tight mount of the heatsink onto the top of the cpu should push out any air bubbles.
Either way, there's no real difference between the temps despite how you lay down the paste as long as the plate is covered.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-982768
Pea, rice, spread, or smush. It doesn't matter. I've even heard you can use mustard. Personally I use Arctic MX-4 and spread it.
I spread it out of habit because before I used Arctic Silver 5 which could cause a short if it smushed out onto the motherboard.
So always becareful even if your paste is just slightly electrically conductive.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-983760
Ketchup vs. Thermal paste.... time to test!
Given your resources you're actually going to test that aren't you? Pics and benches please :3
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/71770-thermal-compound/#findComment-983895
I'd rather not fry any chips... although you got me thinking.
Lets see if an egg frys faster on a GTX 480 or AMD R9 290X
Research and Development at Digital Storm
Personal Website: www.DigitalNav.net
https://linustechtips.com/topic/71770-thermal-compound/#findComment-983901
What you don't have an old Athlon to kill?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/71770-thermal-compound/#findComment-983920
Don't have a board to support it. I think we're getting a bit offtopic here haha.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-983922
Arctic cooling MX-4... Can't go far wrong with that stuff. :D
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
https://linustechtips.com/topic/71770-thermal-compound/#findComment-984266
Heat it up in a glass of hot/ warm water before you apply it so it can spread easier, otherwise it's really thick
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/71770-thermal-compound/#findComment-984303
Pea Method?
Am I doing it right, I defrosted it first but seems a bit large, should I be using tiny baby pea?
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/71770-thermal-compound/#findComment-984332
Pea Method?
You need to boil or steam it first to get the best results.
https://linustechtips.com/topic/71770-thermal-compound/#findComment-984391
