Best, Affordable, Long Term PC Build Help
Solved by Cyracus,
2 minutes ago, TheRoyalDoyle said:ok well lets expand on this then, something that will do 4k in the future if not now.
You really can't make a budget pc that will do 4k acceptably, top of the line hardware is just at that point. Go with 1440p or 1080p and pump the graphics settings to max, that $995 build above should be great for that
Featured Topics
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News0 -
2
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
8
