Best, Affordable, Long Term PC Build Help
Solved by Cyracus,
2 minutes ago, TheRoyalDoyle said:ok well lets expand on this then, something that will do 4k in the future if not now.
You really can't make a budget pc that will do 4k acceptably, top of the line hardware is just at that point. Go with 1440p or 1080p and pump the graphics settings to max, that $995 build above should be great for that
da na ·
Posted in General Discussion1 -
1
Russsell ·
Posted in Networking2 -
4
4
2
resonate ·
Posted in Laptops and Pre-Built Systems0
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
