Hello world! Happy new year!
I have this NZXT H440 (white) with this positiveness air flow (attached below).
The ones coloured in purple is currently blank at the moment, I want my components to stay cool as I want then to last. Would I be wasting my money by filling those with fans? If not, what fans should I buy and should the air going inwards into the case or out?
Many thanks! (Apologies for the crappy MS Paint diagram)
https://linustechtips.com/topic/716196-fans-fans/
At fist, the MS Paint diagram is fine and at least 95% better  than other self made diagrams in the net :D
And for the topic ... LTT has some references for your question
TL;DR most likly yes to ad 2 more fans in the top is probably a wast of money
https://linustechtips.com/topic/716196-fans-fans/#findComment-9126421
I think the setup you have now is great.  I don't see a need to add any additional fans in the top two fan locations.  As long as all four of your intake fans are filtered, I'd keep it exactly how it is now.
It never hurts to experiment a bit, but I doubt that you'll see any thermal improvements by adding anymore fans.
https://linustechtips.com/topic/716196-fans-fans/#findComment-9126423
Your current setup is perfect imo, leave the purple part blank
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/716196-fans-fans/#findComment-9126449
You can add two more case fans on the top to help exhaust the hot air out. The intakes bring fresh air in but without an exhaust helping direct the air then it is more or less just building up inside the case. Having those extra fans will help direct the airflow through your case. It will help pull hot air from the GPU upward because the top of the case will be at a lower pressure than the bottom of the case.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/716196-fans-fans/#findComment-9128514
