Hello everyone,
as a former Playstaytion Gamer I want to build my first PC, but my money and knowledge is limited. (as an engineering student I currently work at 450€ a month)
Next thing is I don't even have peripherals yet so I'm open for every option. 1080p gaming with mid to high settings is enough for me (at the moment!).
This Rig is not thought to be top of the line I want to use it mostly to play racing simulators with a steering wheel, first on one screen later maybe on three so a bit upgradeability should be given.
And I don't want to buy new parts every year so I hope this is enough for a decent PC.
Behind every product I'll tell you my thougts so you understand why i chose those products.
I have absolutely no idea how to choose a motherboard so I hope you can help me with this. Please explain me why you changed some parts (I want to learn something)
Price between 450 to 650€  please note i need peripherals too
BTW I'm open to older Products and used ones as well
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)                 Linus told me this one is enough for gaming :)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg Marketplace)       Had good recommendations
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($46.97 @ Jet)             only one Stick to upgrade in the future (if 4 GB is enough tell me)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Jet)                                  ssd is a must have for every new pc 128gb would be ok too but the pricing was not much different
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  ($67.88 @ OutletPC)                 at least 1TB but for 20€ more i got 2 so I got that going which is nice (1tb would be ok too)
Video Card: Zotac GeForce GTX 1050 Ti 4GB OC Edition Video Card  ($149.99 @ SuperBiiz)   a good gpu I think
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($66.99 @ SuperBiiz)                                looks cool in my opinion (case should have a window)
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($38.49 @ SuperBiiz)       psu from a good brand and 450W should be more than enough
Total: $645.29
Thanks in advance
Felix
https://linustechtips.com/topic/716179-first-try-with-pc-buildig/
4 minutes ago, Feix11 said:
Hello everyone,
Total: $645.29
Thanks in advance
Felix
You have a really good base. Prices do change so always shops around and keep an eye on things. Peripherals start cheap and can get spendy quick to upgrade as you go. Your fundamentals are pretty good with lots of room to upgrade here and there when you get some more money. You will see huge difference compared to console.
Use PCPartPicker Germany. There are a lot of things in your build that could be greatly improved. For instance, rather than wasting your money on a cooler that provide any real benefits over the stock cooler on a locked chip, you could get a better CPU or GPU.
PCPartPicker Germany also has better deals on cases and power supplies. This Nanoxia case is an absolute steal.
Here's a better build with peripherals. However, you'll need a Windows key and a monitor to game. I included those too. The CPU is cheaper, but still performs almost as well, and the GPU is better. The combination will perform a lot better than a 6500 and a GTX 750 Ti. I had to go over budget, but I also included an amazing backlit (customizable) mechanical keyboard and a gaming mouse from Cooler Master.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (€122.84 @ Mindfactory)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  (€53.99 @ Amazon Deutschland)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (€49.33 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€51.99 @ Amazon Deutschland)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  (€196.84 @ Mindfactory)
Case: Nanoxia DS1WIB ATX Mid Tower Case  (€21.86 @ Amazon Deutschland)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (€50.98 @ Amazon Deutschland)
Monitor: Hannspree HE225DPB 21.5" 1920x1080 Monitor  (€93.99 @ Amazon Deutschland)
Keyboard: Ducky Shine 4 Wired Gaming Keyboard  (€42.92 @ Amazon Deutschland)
Mouse: Cooler Master Xornet II Wired Optical Mouse  (€12.90 @ Amazon Deutschland)
Other: Windows 10 OEM Key (Kinguin) (€22.00)
Total: €719.64
Generated by PCPartPicker 2017-01-02 13:24 CET+0100
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Good response, but you don't have to quote the entire, enormous first post. OP gets a notification for every comment, and you can always snip quotes. It makes it easier, as other users don't have to scroll over a page-long response, and far easier for users on mobile, who have to just keep scrolling, scrolling, scrolling.
4 minutes ago, frozeNNN said:
No idea why would someone spend that much money on a case for a low budget build. (cheaper case would mean maybe a rx470)
I included one in my build. There's this 20-euro Nanoxia Case that looks like a Define S, has sound dampening, and is an absolute steal. I could probably do an RX 480 8GB if he/she didn't need a monitor, Windows, and peripherals.
Edited by Aereldor
Clarification
Thanks for the fast replys!
i chose the expensive case just because i liked it and the black and blue colour scheme is with me since long ago (my mountainbike and helmet etc. are black and blue to).
but saving 40€ is good too.
I'm going to add a 128GB SSD to your solution for windows even if that breaks my budget. I like the backlit keyboard! Never heard of that brand before.
Thanks for the help
see you racing!
