Heat sink on backwards
6 minutes ago, isaac22701 said:I know this is a pretty noobish question, but I noticed the other day my new processor was getting hot. I wasn't overclocking so it was a little weird. Today I looked inside and noticed the fan on my heatsink goes againts the airflow of the case (it blows air towards the front of the case). Instead of switching it around, would it be a bad idea to change the direction of the other two fans so that my intake is in the back and exhaust is in the front and would that help at all?
I am going to buy a water cooler in a few months after I get a new case, so it will not be like this for very long.
It depends, most cases have restricted airflow to the front of the case, and most of the time air flows out the sides of the front in little slits, through an air filter. If you're too lazy, I don't think switching the fans around would be that bad, unless you're a temp freak.
