600$ gaming pc help
Go to solution Solved by Antony Leung,
1 minute ago, ChaseKeo said:
This looks good. Because I don't get money often I'm stingy with it, I was wondering if there's anyway to improve this build for the same price. I want to get the best for what I pay
Nope. that build is already good enough. pootis won this round.
I have 600$ and a radeon hd 7770. Don't have a monitor. Have keyboard and mouse. I want it to be as cheap as possible for the best performance. Can you guys help me out? I don't get money often so I want to be as efficient as possible. 600 is honestly more than I want to spend but I can go there.
https://linustechtips.com/topic/715072-600-gaming-pc-help/
600 what? New Guinee Rupee'$?
I ask because 600$ is an odd way of putting it.
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115887
Sell the hd 7770 for 95$ and buy this...
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($109.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($52.88 @ OutletPC)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($41.99 @ Jet)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Best Buy)
Storage: Hitachi Deskstar 2TB 3.5" 7200RPM Internal Hard Drive  ($64.50 @ Amazon)
Video Card: MSI Radeon RX 470 4GB ARMOR OC Video Card  ($173.98 @ Newegg)
Case: Zalman Z1 Neo ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($56.97 @ Newegg)
Monitor: AOC E2260SWDN 21.5" 1920x1080 60Hz Monitor  ($89.99 @ B&H)
Total: $695.28
Generated by PCPartPicker 2016-12-31 01:43 EST-0500
Or instead use a tv you have on your house and dont buy the monitor then.
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115929
you don't need the hdd so that should save you $60
CASE: deepcool dukase v2 MOTHERBOARD: Gigabyte gaming 3 CPU: intel core i5 6500 GPU: Gigabyte gtx 1070 g1 gaming CPU COOLER: enermax liqmax II 120s SSD: Kingston ssdnow uv400 240gb RAM: crucial ballistic sport (1 x 8) PSU: Cooler Master GX 650W
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115945
Total: $695.28
A 7770 won't go for $95 lmao. I can find R9 280/x's for $90-$110
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115976
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard  ($44.99 @ Amazon)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($41.98 @ Newegg)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: PowerColor Radeon RX 480 4GB Red Dragon Video Card  ($191.99 @ SuperBiiz)
Case: DIYPC J180-BL ATX Mid Tower Case  ($34.89 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Monitor: Acer G226HQLBbd 21.5" 1920x1080 60Hz Monitor  ($79.99 @ NCIX US)
Total: $600.71
Generated by PCPartPicker 2016-12-31 01:57 EST-0500
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115980
Total: $600.71
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9115997
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9116001
Total: $600.71
I actually went to buy these parts and when I got down to the storage it is much more expensive than it says. Most of this stuff ends up being a little more because of shipping but I'm mainly concerned about this. Is there another option that you know of?
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9123776
Can try seagate barracuda or WD blue, either will do fine.
https://linustechtips.com/topic/715072-600-gaming-pc-help/#findComment-9123918
