This is windows trying to install an update that you probably interrupted by shutting off your PC.
Leave it for a few days and see if it goes away.
https://linustechtips.com/topic/714076-svchostexe-problems/#findComment-9105828
On 12/29/2016 at 6:49 AM, KacperS said:
There is a problem when I switch on Windows 7. After around 5 minutes the CPU decides to ramp up to 50% usage because of svchost.exe which is a part on Windows and I'm pretty sure malware or something got onto it what do I do?
Try malwarebytes. This same problem plagued me as well. I too was using windows 7. Run a system scan
Indus Monk = Indian+ Buddhist
https://linustechtips.com/topic/714076-svchostexe-problems/#findComment-9105881
