SIMPLE CIRCUIT HELP
Go to solution Solved by mariushm,
Yes, you can connect a resistor across the poles of a battery.
Should you do it? Probably not.
V = I x R  ...  P = I2R  where V = voltage , I = current , R = resistance, p = power
So for example, with a 1.5v battery and a 100 ohm resistor ,  V = I x R so  I = V / I = 1.5v / 100 = 0.015 A or 15 mA , and the power dissipated in the resistor will be  P = 0.015 x 0.015 x 100 = 0.0225 watts, so you need a resistor with a rating of at least 0.125w so that it wouldn't burn up.
With a 10 ohm resistor, you have 0.15A current and  0.15x0.15x10 = 0.225 w of power dissipated in the resistor, so you'd need a resistor rated for at least 0.5w unless you want to see resistors smoking/burning/blowing up.
My advice... don't harm your worms.. they won't learn but as other said, probably they won't come near electricity since they're sensitive to it.
1 minute ago, coldice said:
Can I connect a resistor across the two poles of a battery? I need to know for a science project material thanks. 9_9
Welcome to the Forum!
Sure you could, but why would you? You'd just be throwing power away.
Sig under construction.
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9102941
I need to do this because my science project is seeing if a worm can learn a maze. One side will have a reward and the other sandpaper and then an electric shock. Is there a better way to do this? I know if I don't use a resistor bad things will happen.
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9102947
yes it is a simple application of ohm law. V=IR and power = VI. Make sure your resistor is rated above the power calculation. so 10V with 100ohm will give you 10/100=0.1Amps; 0.1A * 10V = 1W; so you will need at least a 1W resistor.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9102954
Yes, but you'd basically be giving the battery a load and thus using it.
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9102992
Are you testing positive and negative reinforcement or behavioral conditioning?
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9103010
I'm pretty much seeing if an earthworm can learn. Also I was planning on using a D cell. Could I just connect a wire between both poles and then connect a pushbutton in between this wire if the worm touches so I don't waste all of the power, or do I still need a resistor(load)
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9103047
If I used a pushbutton would it stop the current so I can only use it when needed and not let the battery short?
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9103118
Man P.E.T.A. is going to have your face on t-shirts...
Seriously though most worms won't go near any electric fields because they're hyper sensitive to them, well at least that's what the box for my electric nightcrawler probe states.  The thing does work though, it's basically four "D" batteries connected to a steel rod and is enough to drive them right out of the ground in like a 20 foot radius.
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9103124
https://linustechtips.com/topic/713761-simple-circuit-help/#findComment-9103330
