I want to make this build and wanted to ask the community here if they can point out any compatibility issues I might have missed. Also I want to do some overclocking, so should I get a larger psu, and can anyone recommend any minor changes that might make it better (ex. four sticks of ram instead of just two)?
Updated list: https://pcpartpicker.com/list/B7BqNN (the fans are to replace the ones that come with the AIO cooler)
https://linustechtips.com/topic/713044-compatibility-help/
Do you really need the 6800K?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095419
Jesus, whats this build for??
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095421
@LinusTechTipsFanFromDarlo to be fair it fits in with all of his other incredibly premium stuff, i mean 10tb of storage, who the heck even needs that
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095424
also your ram seems kind of low for all the other components, i mean with a build this caliper i would expect at least 32gb
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095427
It's not necessary though, an i7 6700K on a Z170 motherboard would be fine.
زندگی از چراغ
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095430
@LinusTechTipsFanFromDarlo well what is he even doing with it, i mean for editing the extra cores would defenitly be usefull
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095434
one fresh grilled 'overkill' sandwich with extra dip
CPU: Intel Core i7-6850K 3.6GHz 6-Core Processor  ($586.99 @ SuperBiiz)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Jet)
Motherboard: ASRock X99 Taichi ATX LGA2011-3 Motherboard  ($211.07 @ Amazon)
Memory: Corsair Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory  ($189.97 @ Jet)
Storage: Samsung 960 PRO 512GB M.2-2280 Solid State Drive  ($328.99 @ SuperBiiz)
Storage: Western Digital BLACK SERIES 4TB 3.5" 7200RPM Internal Hard Drive  ($196.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 1080 8GB GAMING X 8G Video Card (2-Way SLI)  ($659.89 @ B&H)
Case: Corsair 750D ATX Full Tower Case  ($126.99 @ Best Buy)
Power Supply: Corsair RMx 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($129.77 @ OutletPC)
Monitor: Asus ROG SWIFT PG348Q 34.0" 3440x1440 100Hz Monitor  ($1099.00 @ Amazon)
Total: $5119.50
Generated by PCPartPicker 2016-12-27 14:04 EST-0500
idk
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095447
@Droidbot imo i liked his original build better than that
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095465
@realSpodermani am talking about the build that droidbot posted in the comments of your post
https://linustechtips.com/topic/713044-compatibility-help/#findComment-9095655
