open explorer.exe, right click Computer, manage, Storage Management and I think you have to assign your hard drive to D: drive or whatever there. I can't remember exactly what to do there, but you had to do something there to get it working.
https://linustechtips.com/topic/712443-help-asap/#findComment-9090239
if there are just files on it it should just show up but i had a problem where it didnt when i got my new SSD, what fixed that was hitting restart in windows, not turning it off and on again, the restart button in windows. not sure why just that solved it but it did so try that if your drive isnt showing up
Builds:
https://linustechtips.com/topic/712443-help-asap/#findComment-9090241
I have don't that but it is not there
https://linustechtips.com/topic/712443-help-asap/#findComment-9090260
Open administrative tools (search for it using search bar), there run Windows Memory Diagnoatics; let it restart the PC and do its thing.
This fixes the bug with hard drives not showing up.
The drive needs to be plugfed in, of course.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/712443-help-asap/#findComment-9090295
Stupid question, are you sure it's correctly plugged in? Sata cable from hard drive to motherboard and Sata power from PSU to hard drive? And does it show up in your BIOS/UEFI?
https://linustechtips.com/topic/712443-help-asap/#findComment-9090321
